Steve464
Message 1 of 4
Problem claiming M&S £40-00 voucher
Can anyone assist - Recently ordered BT Infinity from BT via a Uswitch offer on the BT website. Offer included £120-00 mastercard and £40-00 M&S voucher. I have claimed the mastercard but cannot find out how to claim the M&S vouchers.
Bt state that it is not their offer and I must contact Uswitch, even though the offer was advertised and ordered via the BT website.
With research (From Forums) i did find a claim form for this offer however for M&S it is only valid for dates between 29th Sept to 7th October and your order ref must begin with AJM.
My order was placed on the 27th September and order ref begins with VOL
Can anyone assist
Many thanks
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Problem claiming M&S £40-00 voucher
@Steve464 There was a uSwitch offer for a £40 M&S voucher running at that time and you need to claim it on this website https://www.broadbandbenefits.co.uk/marksandspencers/Default.asp  The AJM reference should be on your order confirmation email.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Steve464
Message 3 of 4
Thank you Neil - have just found my AJM ref as you stated. Will try sending off the application form. Thanks very much
Moderator
Moderator
Message 4 of 4
@Steve464 No problem at all, I was glad that I could help Smiley Happy
Kudos”
