Message 1 of 6
Problem updating contact details
Hi,  I received latest bill, it is direct debit.  I clicked to view and a pop up appeared to check contact details, first time I've seen this pop up?  The primary and alternative contact phone numbers are incorrect. I edited with correct numbers and clicked save but a red flash warning: "We found something wrong please try again later". I have tried at least a dozen times over a two day period. Today the last two attempts got response "Details are incorrect" (They were not?)  I'd be grateful for any advice. Thanks in advance
5 REPLIES 5
Message 2 of 6
Re: Problem updating contact details
Hi @johnslevin
I'm sorry to hear that you're having trouble viewing your bill.
Are you trying to view your bill via the BT App or your BT online account?
Chris S
Message 3 of 6
Thank you for your response. It is via my online account, the actual problem is a pop up window appears for me to confirm my contact details. All details are correct apart from primary and alternative contact phone numbers. I follow procedure to Edit and Save correct contact numbers, but keep getting "Sorry we found something wrong, please try later"
Message 4 of 6
Thanks for letting me know @johnslevin
Do you have the same issue when you try to load your bill using your BT app?
Chris S
Message 5 of 6
I don't have problem reading my bill, only updating/correcting my contact  phone numbers on a pop up window when checking my bill . BT merging with EE has resulted in shoddiness. I'll scour this nightmare of a website and see if I can get a result elsewhere.
Message 6 of 6
@johnslevin
try contacting billing using message now and they should be able to help you
https://www.bt.com/help/contact-bt/account-and-billing/broadband
