lernien
Message 51 of 54
Re: Pure Pre-Paid Visa Card
Yes I've tried that the little box that you need to untick it makes no difference.
Message 52 of 54
You have to tick the box to select the ones you want to remove, then select the options menu to remove the ticked subscriptions.
Kuzey101
Message 53 of 54
@RobbieMac Thanks for the follow up. No the card has not arrived. I received an acknowledgement to my chaser email saying :
"Thank you for your email.
I will need to send a request for further investigation before we’re able to send a replacement visa card.
This can take up to 10 working days, however we will contact you again at the very earliest opportunity with the outcome.
Thank you for your patience while we investigate this for you."
This seems to suggest that a card has been sent and simply gone astray but I am not convinced that is the case.
If you are able to resolve more quickly I would appreciate it.
Moderator
Moderator
Message 54 of 54
Hi Kuzey101,
Thanks for posting back.  Sorry you still haven't received it.
Click into my profile and under the section "about me" you'll see the link to send over your details.  We'll get it sent out to you.
**At the OP's request I'm now locking this thread.  For the guys I've offered help to this morning, follow the above steps you get your details over to us**
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
