nihaldes
Message 11 of 34
Re: Quidco cashback declined
Hi @JohnC2
I have received an email from Quidco today saying that my cashback has been declined by the retailer as it has been returned or cancelled which is not the case as you know.
Could you check with your promotions team that they have authorised the payment as you advised previously.
Many thanks
Nihal
Moderator
Moderator
Message 12 of 34
Hi @nihaldes@JohnC2 is not in the office this afternoon but I'll make sure he gets your message in the morning.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
nihaldes
Message 13 of 34
Thanks @NeilO, are you able to check with the promotions team in the meantime?
Moderator
Moderator
Message 14 of 34
@nihaldes sorry I can't @JohnC2 will have an email chain from them in his inbox which I don't have access to.
Kudos”
nihaldes
Message 15 of 34
ok no problem thanks
Moderator
Moderator
Message 16 of 34
Hi @nihaldes Sorry that you received that email from Quidco. I'll go back to the promotions team and I'll update you as soon as I hear back from them.
Cheers
John
Community ModeratorJohnC
Kudos”
nihaldes
Message 17 of 34
Thanks John, much appreciated
nihaldes
Message 18 of 34
Hi @JohnC2
I received a cheque today for £50 as cashback, however the tracked cashback is for £120. Could you speak to the promotions team and find out why they only sent a cheque for £50?
nihaldes
Message 19 of 34
Hi @JohnC2, just wondered if you'd managed to speak to the promotions team about this?
Moderator
Moderator
Message 20 of 34
@nihaldes I'll leave a message with @JohnC2 to get in touch with you tomorrow as he's not in the office today.
Kudos”
