Moderator
Moderator
Message 11 of 13
Re: Quidco cashback declined
Hi @waddis25  sorry to hear that you have still not received the cashback. I've been in touch with the promotions team and they have escalated this with Quidco. Please keep an eye on your cashback balance and I'll update you as soon as I can.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 12 of 13
Hi @waddis25  The promotions team have got back to me and told me that this has been escalated with Quidco and should be resolved within 72 hrs. Please can you check on your cashback account and let me know that you have received it ok this time.
cheers
John
Kudos”
waddis25
Message 13 of 13
Hi yes, I have now received the cashback.
Thanks for your help.
