Robert11
Message 1 of 7
Re: 4g mini hub switched off and can't be switched back on
BT want to turn our mini hub off but our main hub hasn’t been fixed 100% therefore occasionally we are still using the mini hub especially for school work how can I stop BT turning it off?
6 REPLIES 6
Robert11
Message 2 of 7
4g hub
Keith_Beddoe
Message 3 of 7
Re: 4g hub
Does you main broadband now work, if not, then what is the problem?
Robert11
Message 4 of 7
Re: 4g hub
Doesn’t work 100% intermittently goes off still
Keith_Beddoe
Message 5 of 7
Re: 4g hub
Do you mean that the lights on the home hub change colour?
Is there any noise on your phone line?
Robert11
Message 6 of 7
Re: 4g hub
Yes the main hub changes colour have reported fault etc but still intermittently happening
Hardly use house Phone
Keith_Beddoe
Message 7 of 7
Re: 4g hub
Most faults are caused by high resistance faults, made worse by the fact that there is no electrical path created by the house phone.
Please can you plug in the house phone. Then dial 17070 and select option 1, ringback test.
Then put the phone down, and it will ring. Let it ring for about 20 seconds and then answer it, you will then get the message that the test is complete.
You can then put the phone down, but I would recommend that you leave it plugged in.
The high voltages generated during the ringing, usually breaks down any bad connection.
Another question.
What does your master phone socket look like?
