Newbie
Message 1 of 13
Re: Broadband upgrade
Upgraded due to go live 20th sept got texts to say engineer was out and everything should be up and running now which it isnt nothing works at all just constant flashing orange light the thing is everything was fine until i upgraded
12 REPLIES 12
Message 2 of 13
does your phone work
upgraded from what to what?
Newbie
Message 3 of 13
Normal broadband to fibre
Newbie
Message 4 of 13
Have a dial tone also but when try to ring phone it rings once then cuts off
Message 5 of 13
have you tried connecting to test socket with a filter and see if phone works and if not report fault to 151   if it does work in test socket then check broadband by connecting router to filter still using test socket
Newbie
Message 6 of 13
Ye done all that cheers
Moderator
Moderator
Message 7 of 13
Hi @Bluecoopy79 As you have reported the fault already have you given a date for an engineer visit or is the fault external?
John
Newbie
Message 8 of 13
Engineer just been nothing wrong with anything apart from not having the correct equipment etc which iv argued with six different indians about
BT ARE A JOKE
Message 9 of 13
You should have a BT Home hub 5, or home hub 6.
Newbie
Message 10 of 13
Which iv been telling bt but they keep saying iv got home hub 4 which is fine
