JohnC2
Moderator
Moderator
Message 11 of 22
Re: Still no M&S voucher
Hi @Meyrick thanks for the update and sorry you have not received the M&S voucher. I've re-opened your case and I will check with the promotions team next week and if it arrives in the meantime just post back and let me know. If it doesn't show up I'll be back in touch once I get an update for you.
cheers
John
Meyrick
Message 12 of 22
Thanks John, it is very much appreciated.
JohnC2
Moderator
Moderator
Message 13 of 22
Hi @Meyrick  I'm still waiting on a reply from the promotions team but a few of my other vouchers from around the same time have now arrived. I wanted to check if you have received yours yet?
cheers
John
leenemesis
Message 14 of 22
Hi John am I in the list as well?
NeilO
Moderator
Moderator
Message 15 of 22
Hi @leenemesis yes you're on the list, we'll get back to you in due course.
Meyrick
Message 16 of 22
Hi John
No nothing has arrived so far, thankyou for asking.
Best wishes.
Chris.
JohnC2
Moderator
Moderator
Message 17 of 22
Hi @Meyrick  the promotions team has replied to me to say the voucher has been posted on the 27th of this month. It should be with you within the next week.
Cheers
John
Meyrick
Message 18 of 22
Hello John
The voucher has arrived today, I assume it is for the right value as there is nothing printed on the card itself, but the correct amount is mentioned in the accompanying letter. Thanks once again for all your help with this, I think this is the end of the road, so you may close our query.
Have a good year if you can, and stay safe!
Best wishes.
Chris.
PaddyB
Moderator
Moderator
Message 19 of 22
Hi @Meyrick,
That's great, thank you for posting back to let us know. Once again please accept our apology for the delay.
PaddyB
leenemesis
Message 20 of 22
Hi Neil I have now my MasterCard so thank you for chasing. Will the M&S one come seperately which I didn't receive. I did try and claim last week and website said already claimed for so hope it's on the way. Cheers
