Hi John, Ive got that same problem as ADIEJOL. Where BT Have canceled my order and set up a new with a different transaction number and therefore does not match the topcashback one. Total cashback is for£130. thanks
I have moved your post to this new thread, so you can get personal help.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Hi @jojo676 have you reported this to Topcashback yet? They have a process in place for this very scenario if you lodge a cashback claim on this link. If you've encounter any problems with them we can raise it to our cashback team but you need to report it with Topcashback first.
Community Moderator | NeilO | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the star next to a reply to say thanks | Help guide to using the community? Click below |
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You |
Hi @jojo676 Thanks for the update. Once your services are activated please complete a Missing Cashback Claim with TCB. Provide them with the original order ref and the replacement order ref and they will be able to process your claim for you.
Drop back and let us know how you get on.
Cheers
John
Community Moderator | JohnC | |
thanks john, will do.
