chr15toffer
Message 1 of 10
Re: ORDI Request to Openreach
Hi John
I know this thread is a bit old, but I'm desperately trying to get some help to get an ORDI request raised for a new build property I've just moved in to. Can you help?
Thanks,
Chris
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
@chr15toffer
Welcome to this user forum.
An ORDI request only applies to a working line, which I assume you do not have yet?
Has the new build got  a direct fibre connection, similar to this?
chr15toffer
Message 3 of 10
Hi Keith
Thanks for the quick reply. You're right, as far as I know there is no working line yet. 2 of the 8 flats in the block show up in the various providers' address lists, but mine does not, so I was thinking they have been through this process successfully somehow. I'm not aware whether there is a direct fibre connection, I guess that would be in a central maintenance area of the building somewhere? In my flat there is a socket marked 'Master Socket 5C' and 'Openreach', if that helps at all?
Chris
Keith_Beddoe
Message 4 of 10
Then all you have is a socket.
Your address will be listed as a bronze address.
You will need to place an order for a phone line first, from a Service Provider.
Are you intending to order your service from BT Retail?
Is your address correct on the Royal Mail Postcode Database?
chr15toffer
Message 5 of 10
I've been told that my address is currently listed as silver. Yes, it is listed in the RM postcode database. BT seems to be the only option, other providers have told me that they can't or won't do whatever is necessary or that their service simply isn't available to the postcode.
Keith_Beddoe
Message 6 of 10
If you are going to use BT Retail.
You should still be able to get an order placed for a line only using this link - https://www.bt.com/landline/deals
If the address doesn't appear properly when you enter the postcode, there is a section underneath where you can manually enter the address.  This will raise the order with the address showing as bronze and it will prompt Openreach to carry out a survey to confirm the routing.   Once the routing is updated the order will then progress as normal.  You can then add broadband once you have the line up and running
This forum cannot help with any other provider, you would have to contact them instead.
There may be a reason why they do not or cannot provide service. It could be that the speed is going to be below 2Mbs, or there is only a fibre connection to the properties, and they do not sell that service.
chr15toffer
Message 7 of 10
Keith
Thanks for your help and the explanation, it's very useful.
Chris
RUISGARRY
Message 8 of 10
I am sorry no further forward, disappointed in response from BT, all going well on Communuty chat, as soon as I was to private message an employee of Ooen Reach all communications stopped ... back to square one 😡
Keith_Beddoe
Message 9 of 10
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
imjolly
Message 10 of 10
@RUISGARRY
Have you actually placed an order with BT for a phone line
