mispeltyuoth
Message 1 of 4
Re: Online Billing - not displaying billing & usage
Hi @RobbieMac , @JohnC2
I know I've jumped on the back of someone else's thread but I'm having the exact same issue except I DO use an email address to login to my account. All I get when I try to see my usage/bills is this
I don't really want to download my bill just to see my usage.
3 REPLIES 3
JohnC2
Moderator
Moderator
Message 2 of 4
Hi @mispeltyuoth, I've moved your post to create your own thread as that's the best thing to do as the issue is different as your BTID is an email address.
Are you trying to access your bill via www.bt.com/mybt or is that screenshot from the app?
Were you able to view your bills/usage ok recently or has it been like this for a long time?
cheers
John
mispeltyuoth
Message 3 of 4
Apologies @JohnC2  - I've been away for a week and didn't get a notification you'd responded.
The screenshot is from www.bt.com/mybt and I honestly can't remember the last time I've been able to see my bill without downloading the pdf. I can currently see my bill on the app but, to be honest, even that's a bit hit and miss
As it happens, I checked today and now it shows this:
I accept that the latter may be a temporary issue.
Thanks for any help
JohnC2
Moderator
Moderator
Message 4 of 4
Hi @mispeltyuoth, thanks for the update and hope you had a good time away. I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you get this fixed.
cheers
John
