Message 1 of 20
Re: Upgrade required to view this content
BT Sport tells me I need to upgrade my package whenever I go to play any live sport. It works through my BT TV box but not my laptop, or the BT Sport app on my other television. I have tried using an Xbox One with the app too. I have also tried all previous suggestions and they haven't worked. Resetting cookies etc.
19 REPLIES 19
Message 2 of 20
Re: 'You need to upgrade your package to view this content' - BT Sport monthly pass
Do you have full subscription to BT Sport or is it one that comes free with a mobile package? If it's the free version, it's only for small screen access
Message 3 of 20
Re: BT sport app says I need to upgrade subscription but I've got a monthly pass?
@JamesBrennan1Do you have BT TV with an active BT Sports addon ? the monthly pass is something different.
If you can watch on BT TV but not any other device, I suspect your BT ID doesn't have you listed as the account holder, can you try the following :
Please follow the steps below:
  1. Log in to My BT >
  2. Click on Settings and Your account
  3. Scroll down and you'll see if you're an Account holder or Account manager
  4. Click on the I should be the Account holder link and follow the steps
Message 4 of 20
James has contacted me directly, and I can confirm that there is an issue with his BT ID. This will be manually resolved tomorrow.
Message 5 of 20
Just to update on this one - as a result of this investigation, we have identified an issue with our ordering system that also affected over 1200 other customers. Those accounts are now fixed, and the system has been corrected.
Message 6 of 20
Hi Darren, mine is still not fixed. I pay for the monthly pass but my app is telling me I am only the light subscription and need to upgrade on every channel. Please help.
Message 7 of 20
Send me a DM with your BT ID and I'll check it out @wphill
Message 8 of 20
I'm still having the same problem.
Message 9 of 20
Can you please send me a DM @mattmurphy218 so that I can take a look at your account
Message 10 of 20
Hi, apols for the thread bump. I am having this same issue with my BT Sport Ultimate thru EE. I can't view anything on Xbox Series S, Roku app or web browser.
Online support chart was less than helpful.
Could you help me please?
