Flower5771
Message 1 of 3
Re halo 3
I’ve just upgraded to halo 3 will I receive a new hub or use existing one thanks
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: Re halo 3
Hi @Flower5771 welcome to the community and thanks for posting, no with Halo 3 you'll continue with your existing Hub.
But you do get a new Smart Hub 2 and Hybrid connect Hub if you choose the Halo 3+ plan
Neil
Flower5771
Message 3 of 3
Re: Re halo 3
Thank you so so much
Regards Jill
