paralimni201
Message 1 of 2
Re: rewards card pin number
Hi I am having the same problem re pin. Can you send me info please?
Roger Whittle
Paralimni201
1 REPLY 1
RobbieMac
Moderator
Moderator
Message 2 of 2
Hi @paralimni201,
Welcome to the Community and thanks for your post!
Sorry for the problems with your PIN.  You can access your PIN by logging in to your online account at www.purecard.com and going to "My details - Security - View PIN".  If you're still experiencing problems, call 0344 879 1068 or email bt@purecard.com
Cheers,
Robbie
