SpookyAnna
Message 1 of 6
Refer a friend
Hello Everyone
I have been with BT for over a month and was refered by a friend.  Both of us received and email on 15th December saying that our £50 Amazon voucher would be on its way.
I have paid 2 bills since then and my friend has paid 1.
When do you think we should receive the voucher?????
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: Refer a friend
Hi @SpookyAnna, thanks for your post and also recommending a friend to us. On the Refer A Friend offer it does say it should be within 45 days from the date your friend's broadband is activated. You should visit the online status checker to check the status of your referral. You can do this by following the link you received in the email we sent you when your friend joined.
Cheers
John
SpookyAnna
Message 3 of 6
Re: Refer a friend
Thank you for your reply JohnC2.
Shall I refer back here if nothing is received by Friday of next week (29th January) which is the 46th day.
I would point out that the email received on the 15th December did say that the voucher should be received with 30 days🤪
JohnC2
Moderator
Moderator
Message 4 of 6
Re: Refer a friend
Hi @SpookyAnna, thanks for posting back and certainly do come back to us here next week if you don't have the voucher.
What does it show when you check the status of your referral at the moment?
cheers
John
SpookyAnna
Message 5 of 6
Re: Refer a friend
Hello again John 😄
Where do I find the online status.  Is it on MyBT?  Or somewhere else??
JohnC2
Moderator
Moderator
Message 6 of 6
Re: Refer a friend
Hi SpookyAnna, for the status it says you should visit the online status checker to check the status of your referral. You can do this by following the link you received in the email we sent you when your friend joined. I just wanted to know if you could see the status and if it looked ok for the voucher.
thanks
John
