Message 1 of 7
Regrade to full fibre mid-term
Does anyone know if it's possible to regrade from FTTC to FTTP mid-term? I'm due to end my Virgin Media contract in September, CityFibre have dug our road up twice in the last 3 months to put the full FTTP infrastructure in but it's not likely to be live when my VM contract ends.... so I either get tied to VM for another 18 months (on their 1.2Gbps service 0- which to be far has been almost faultless), or switch now but will be stuck on a max speed of 35Mpbs (all I can get on the current openreach cr*p) until BT roll out the full fibre in my location...
6 REPLIES 6
Message 2 of 7
Re: Regrade to full fibre mid-term
If you moved to BT FTTC then you can upgrade to FTTP whenever that becomes available
Message 3 of 7
@littledavehedgehog
Do VM not let you have a rolling 30day contract like most ISPs do?
Message 4 of 7
Yes they do but depending on how you negotiated over the years at end of each contract it could end up being a huge price rise as all negotiated discounts would be lost.
Message 5 of 7
@Tim Yes they do, but it's twice the price
Message 6 of 7
Excellent, thanks for the info
Message 7 of 7
@pip I'm not currently with them, so that's not an issue
