Message 1 of 5
Remove Old BT Account Links
My BT account has an old account linked which the app defers to on opening. The old account May also be affecting the way I can view offers and make changes. Making the use of BT online services to do anything really clunky and not use friendly.
How do I remove the old link?
4 REPLIES 4
Message 2 of 5
Re: Remove Old BT Account Links
Any simple solution?
Message 3 of 5
Hey @jimendersby,
I am sorry that there's no easy way for you to remove it.
This is something that I can do for you. I have sent you a private message with some of the details that I need to get it removed for you 🙂
DanielS
Message 4 of 5
Thanks for sending over the details @jimendersby .
I've removed those old accounts for you now.
Cheers
David
Message 5 of 5
That’s brilliant, worked a treat!
