Message 1 of 4
Remove a closed account from MyBT
I would like to remove a closed account form MYBT.
3 REPLIES 3
XRaySpeX
Recognised Expert
Message 2 of 4
Re: Remove a closed account from MyBT
Phone BT on 0800 800150 & ask them to remove it.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 3 of 4
Hi
I am sorry to see you are having problems
I suggest you contact live chat at this link they should be able to help you
http://bt.custhelp.com/app/contact/c/2902/?s_intcid=con_intban_sanda_contact_us_chat_from_forums
Moderator
Moderator
Message 4 of 4
Hi @daphnesharman,
Try contacting BT as suggested by @XRaySpeX and @john46. If you have any problems after that in getting that removed, post back and I'll take a look at this for you.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
