Message 1 of 3
Requesting a change of package
Hello,
If it is possible please could my landline package be changed from unlimited weekend and evening calls back to the basic package of unlimited weekend calls?
I've thought of phoning support but I have a hearing impairment and a problem with my voice which makes calling and others understanding me very hard, and I've tried the live chat but it always gives me a "connection unavailable" error.
Sorry if this is a bother, but this way seems to be the only other way to do it as I cannot remove the "add on" in my BT.
Thank you
2 REPLIES 2
Message 2 of 3
Re: Requesting a change of package
Products can not be changed via this forum. You should contact BT 0800.800.030 who should be able to help.
Message 3 of 3
You will need to call in: 0800800150. However, you will find that the calling plans have changed. Depending on how you're set , you may not be able to revert to weekend only. New options are 500 minutes (mobiles & landlines) for £5.00 per month, or no monthly charge for pay-as-you-go giving you 20p per minute to mobiles and landlines with no call set up fee.
