on 02-11-2020 22h33
I've just changed from Halo with complete Wifi to Fibre 1 and BT want the Wifi discs back, Do I understand right, that if I don't return them, I get charged £30 each for them ? So is it OK to keep them and pay ??
on 03-11-2020 9h40
That is correct that if you do not return them you will be charged £30 per disc.
See link
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
If you do want to keep them you should contact BT 0800.800.150 and inform them of that so that you are not plagued with reminders.
