BigE1
Newbie
Message 1 of 2
Reward card
Hi
ive recently took out a contract for phone and fibre broadband, the service was meant to commence on the 16th July but never did, so after several phone calls later I discovered that there was some technical issue and it didn’t go live till the 19th the guy I spoke to said he would put in a formal complaint and that I would be compensated for the inconvenience but I’ve heard nothing since, also part of the deal I took out was for a choice of free tech and a BT reward card, I’ve had the free gift but not had the reward card, I’ve tried ringing customer service but got nowhere
1 REPLY 1
albertj
Message 2 of 2
Re: Reward card
Is your broadband up and running now?
Have you tried claiming it: https://www.bt.com/manage/bt-reward-card/
Failing that, you could get in touch with the Rewards Team: https://bt.custhelp.com/app/contact_email/c/6090
A mod will hopefully help you out as well if you still can't claim it.
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
