ThomasKL
Message 1 of 15
Rewards Cards
Hello
Could anyone tell me where you claim your reward cards? I signed up for a Broadband and Mobile package at the end of January, mobile went live on February 2nd and my Broadband went live yesterday. I'm eligible for a £125 BT Reward Card and a £40 BT Reward Card but I have no idea how to claim them?
14 REPLIES 14
Message 2 of 15
Re: Rewards Cards
Welcome to this user forum.
Use this link claim my reward
ThomasKL
Message 3 of 15
Re: Rewards Cards
Thank you.
Could you point me in the direction where it is on the page. When I click that link it just takes me to My Bt homepage?
Message 4 of 15
Re: Rewards Cards
It should take you directly to a login page for MyBT, it does here, and other people have confirmed it.
Try logging out of MyBT, then try the link again.
ThomasKL
Message 5 of 15
Re: Rewards Cards
Yes it does take me directly to the MyBT login page. But where exactly is the claim reward section? I don't see anything about claiming a reward.
Message 6 of 15
Re: Rewards Cards
Not sure, as I have not used that page myself. Perhaps a moderator can explain where it is?
Moderator
Moderator
Message 7 of 15
Re: Rewards Cards
@ThomasKL when you login using your BT ID it should present the claims form. Have you tried logging in with your primary BT ID?
ThomasKL
Message 8 of 15
Re: Rewards Cards
Hi thanks for the reply.
It's all sorted now. I spoke to customer services on the online chat and they have put the rewards through for me.
Moderator
Moderator
Message 9 of 15
Re: Rewards Cards
@ThomasKL Great, thanks for the update Smiley Very Happy
BeeteeSucks
Newbie
Message 10 of 15
Re: Rewards Cards
BT makes the claiming difficult in the hope it's forgotten or expires, this is poor practice. The links are usless and redirect to a log-in page. Please provide a valid link for the REWARD CARDS AS ADVERTISED IN THE JANUARY PROMOTION!
Just be advised, BT charge a ridiculous 10p per MB mobile data outside of limit (cap this asap if new), you wont get the advertised speed and will have to invest time into getting your so called rewards.... They are 100% efficent in taking money from your account 10/10 in that department.
Perhaps my worst experience... stick with Virgin or Sky.
