Kblair
Message 1 of 4
Rewards card not received
Not received rewards card
Orderd my card on the 22nd September waited the 30days nothing then emailed bt told it would be 10 more working days still no card contacted by again said they would need to investigate but this would take 5 working days can anybody help they just seem to be phobing me off
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Rewards card not received
Hi @Kblair,
I'm sorry you haven't received your BT Rewards Card. I'll be able to chase this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 3 of 4
Hi @Kblair,
Thank you for sending in your details. I've passed on your details to my colleagues in the Rewards Team and I've asked them to investigate. It normally takes them around 48 hours to get back to me and I'll post back an update as soon as I know more.
PaddyB
Kudos”
Moderator
Moderator
Message 4 of 4
Hi @Kblair,
The Rewards Team have got back to me and they've apologised for the delay. They've had to request a new rewards card and this will arrive in the next 30 days.
PaddyB
Kudos”
