Redsox67uk
Message 1 of 2
Sky cinema subscription
If I changed my mind about sky cinema after cancelling the subscription how do I get it back ? Can't seem to do it online...
1 REPLY 1
-Richie-
Expert
Message 2 of 2
Re: Sky cinema subscription
Do you still have access to it now ? as in going through a 30 day cease order, if so ring 0800 800 150 and ask for the cease order to be cancelled, it will then remain active.
If it has gone off, you should be able to subscribe again by attempting to view Sky Cinema and you should be able to do so via the Youview box or you can speak with the Loyalty or Value team on the same number above.
