Keith_Beddoe
Message 11 of 28
Re: Superfast Fibre 2 Unlimited installation problems
It should really be quiet.
Can you please unclip the front cover, and plug a microfilter into the test socket and plug the home hub into that. See if it now connects.
If you have any other extensions, you should see them connected to the terminal block on the left.
rab123
Message 12 of 28
Okay, I've done that and the hub still flashes pinky-purple.
Keith_Beddoe
Message 13 of 28
Is that the only phone socket you have?
What connection speed did BT say you should get?
rab123
Message 14 of 28
Yes it's the only phone socket, i think the speed was up to 70 with a 60something average.
Keith_Beddoe
Message 15 of 28
It could be two things.
A faulty home hub. Which home hub do you have?
A commisioning error.
Have BT offered to send another home hub?
rab123
Message 16 of 28
It's a BT Smart hub, they haven't offered another one. What is a commissioning error?
Keith_Beddoe
Message 17 of 28
Its possibly a faulty hub, as that does seem to happen from time to time.
A commissioning error means that the broadband has not be provided correctly. This should not happen in theory.
Assuming you have everything connected up correctly.
BT Hub set up
BT Hub set up
Then I would as BT to send a replacement home hub, as that would be the quickest way to prove it, unless you have another suitable home hub you can try?
Gary_C
Expert
Message 18 of 28
I read the first post as if the installing person stated that the broadband connection hadnt been done and would need someone to do it ?
Keith_Beddoe
Message 19 of 28
Its not possible to tell, as it could be a faulty home hub, that is the first thing to try. If that does not help, then BT would arrange a visit, to check the connections.
I assume everything is connected up as shown on those pictures?
rab123
Message 20 of 28
Yes it's all connected properly & I don't have another one to try.
I just got a text saying that I need to book an appointment and checked the fault tracking and the Openreach appointment for Tuesday has disappeared. So called BT and now Openreach are going to check the junction box tomorrow at some point & I don't need to be here for an appointment.
