barneys
Message 1 of 4
Supporting Elderly relative
Does anyone know if you can set up an arrangemnent with BT whereby I can talk to BT about an elderly relatives account? I have done so with other Utility companies.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Supporting Elderly relative
Hi barneys,
Thanks for posting. I'm sure we can help with this. Drop me an email with the details. You'll get the 'contact us' link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
MACCERS1975
Newbie
Message 3 of 4
Hi DavidM,
Can I contact you regarding a very similar enquiry, albeit with a few more complications?
thanks
Moderator
Moderator
Message 4 of 4
Hi MACCERS1975,
I'll be able to take a look at this for you. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Kudos”
