dastardley
Message 1 of 10
Switch over time?
Getting Full fibre 100 installed tomorrow....was wondering will my present internet stay working up until the full fibre is installed? Have someone working from home (call centre operator) who needs to be connected online....was wondering if the disruption to service between switching from old service to new will be long?
9 REPLIES 9
dastardley
Message 2 of 10
Re: Switch over time?
anyone?
DavidM
Moderator
Moderator
Message 3 of 10
Hi @dastardley and thanks for posting.
Usually you'll only be 'down' for the length of time the engineers are working to install the new fibre connection. My own was completed in under 2 hours.
Hope that helps.
Cheers
David
dastardley
Message 4 of 10
Thanks David, how many electric sockets does the fibre equipment need? My current openreach box only needs one.
licquorice
Message 5 of 10
2, one for the ONT (modem) and one for the Hub (router)
dastardley
Message 6 of 10
Oh, oh.....I only have one main socket available in the space I use, unless the can plug the router into the extension lead I use for my PC, TV, TVbox?
Keith_Beddoe
Message 7 of 10
You would need one for the Openreach ONT and one for the BT Home Hub.
dastardley
Message 8 of 10
would i be able to use an extension lead for the bt hub yes?
imjolly
Message 9 of 10
no reason why you cannot use the multi extension to plug in your router - not a problem
dastardley
Message 10 of 10
Cheers imjolly.....that's a relief! Much appreciate the reply...Thanks.
