Message 21 of 21
Re: Switching Broadband
@CommunityBob
When you reply to a post it would be helpful if you either include the username of the person you are replying to, which you can do by opening a reply box then click on " shift @ "  This will bring up a list of those that have posted on the thread and you can click on the one you are replying to.
Alternatively you could quote the post that you are replying to. To do that click on "reply" then go to the three dots ... in the menu bar. Select the quote marks ''  which will place the post that you are quoting into the reply box. If you move the cursor below the quoted text box you can then add your reply to it.
