BabsH
Message 1 of 5
TV Packages
If you want to change your TV package, which you are allowed to do every 30 days does the change take effect immediately?
4 REPLIES 4
dfel100
Message 2 of 5
Re: TV Packages
It did when upgraded to the sport package.  I did have problems cancelling it online, had to phone BT customer services to cancel it, but that did that with no problems.  Good luck
-Richie-
Guru
Message 3 of 5
Re: TV Packages
If you upgrade (add more content) it happens midnight the next working day, if you downgrade (remove content) it happens on the renewal of the pass/billing cycle.
BabsH
Message 4 of 5
Re: TV Packages
Thanks for the information.
ney
Expert
Message 5 of 5
Re: TV Packages
When I upgraded from Entertainment Max HD to the Now TV Big Entertainment package with HD add on last March. The switch happened with in 5 or 10mins of me coming of the phone with BT. I just had to register my email with Now TV to get the on demand tuff.
I cancelled BT Sport at the same time but that toke at lest 10 days before they switched it off as I had to give 14 days notice for cancelling BT Sport so the guy said but I was not charged any extra from the point I cancelled BT Sport.
Darren
