Message 1 of 4
Taken up with BT deal Help needed
I have joined BT again after a couple of years but having problems before going live .Having contacting BT 4 times I’m not sure things are fixed.I’m due to be connected on 17;June.
proble was my order did not work correctly because of Nextfix on my order. They also gave me the wrong account number which need changing. They have said 3 times it has  been fixed the order I’m unable to verify my BT ID it keeps failing. I had email to claim my £90 voucher now I can’t seem to claim it for some reason. I’m 72 years old and this has got me around the bent.
can someone from BT Help me out.
3 REPLIES 3
Message 2 of 4
Re: Taken up with BT deal Help needed
The mods on the forum do not have account access so maybe try billing using the message now link
https://www.bt.com/help/contact-bt/account-and-billing/broadband
you cannot claim your voucher until your cooling off period has passed which with activation on 17th June will be about 17 July
Message 3 of 4
Thanks for your response
Have spoke with billing they say it's tech problem who say it the team doing new orders .
I'm at the point of given up on Monday by telling BT to cancel the whole order.
James
Message 4 of 4
Re: Managing Sub-Acccounts
This is has nothing to do with
My email address it is ok. Found out verification of BT ID IS a prou
My problem is BT Have problem with my order. I have.2 accounts numbers one is wrong the other correct confirmed by BT
Many Thanks
