DanielS
Moderator
Moderator
Message 11 of 14
Re: TopCashback claim rejected!
Hi @Sean52d,
I've had my private messages off over the last few days that I was out of the office. I'd like to check in with you to see if you are happy with my reply. Do you need any other help or are you happy to close your case?
DanielS
Sean52d
Message 12 of 14
Hi Daniel,
Can’t seem to find or remember using voucher codes if I’m honest so not sure what’s happened there!
DanielS
Moderator
Moderator
Message 13 of 14
Hi @Sean52d,
They have been picked up as the referrer. They have their own offers so it may be worth checking with them if you have an account. If you still have your internet history from the time of the order it may show up in there.
DanielS
DanielS
Moderator
Moderator
Message 14 of 14
Thanks for taking the time to speak with me today @Sean52d.
I haven't had a reply back from the team yet which means that they may not get back to me until Monday. I'll be in touch with you on Monday.
DanielS
