Moderator
Moderator
Message 11 of 22
Re: Yet another with reward and cashback problem.
Hi @insa80 and thanks for posting.
I'm sorry it's taking so long to get the cashback sorted. I'll be happy to check if there's anything we can do to help. Can you please send over your details using the contact link in my profile and we'll take it from there.
Cheers
David
insa80
Message 12 of 22
Thak you I will try again through you but I just got a repsonse in my e-mail from one of BT advisors I guess that they can't see me being eligable to any Cashback and I am confused now as why Topcashback page says my cashback has been Confirmed by Merchant and BT says they do not know anything. Is the Merchant Topcashback referring to not BT?
insa80
Message 13 of 22
Cannot seem to find contact link
Message 14 of 22
Use the link as shown below.
https://community.bt.com/t5/user/viewprofilepage/user-id/17
insa80
Message 15 of 22
Thank you. But there is no link visible...
Message 16 of 22
I have asked for it to be posted by a different moderator.
Moderator
Moderator
Message 17 of 22
@insa80 I can see that @DavidM has made the link visible to you but you'll also see it if you click on my username. The link is on the left hand side of the webpage under the about me section.
insa80
Message 18 of 22
Thank you. GOT the link!
Moderator
Moderator
Message 19 of 22
@insa80 That's great, we'll be in touch in the next few days as we're quite busy in the Mod team at the moment.
insa80
Message 20 of 22
Thank you. Will be waiting on update.
