insa80
Message 21 of 22
Re: Yet another with reward and cashback problem.
Thank you very much for all your support. I just logged into my Topcashback account and BT broadband cashback amout has been put as Payable.
Still waiting on BT Mobile update though, but it is not confirmed yet so will have to wait if it will be Confirmed at all.
Moderator
Moderator
Message 22 of 22
@insa80 That's great thanks for posting the update, as the BT Mobile order was placed a month later it will likely take longer for the cashback to be confirmed.
