Hi. Can anyone help me please? I have been a BT business customer for many years and am now semi-retiring so wish to transfer from business to residential and keep my existing telephone number. I have been passed back and forth between the business department and residential and are no further forward. Suggestions welcome, thank you.
Solved! Go to Solution.
It should be fairly straightforward, but you may get a short period with a temporary number.
Both services would come from the same exchange building, provided you are not moving.
This is how I would suggest.
Because BT Business and BT Residential are separate parts of the BT Group, you would have to place an order for a phone line from BT Residential as a working line takeover.
BT Residential would give you a new phone number, but you should be able to ask for a re-number back to your original number.
There may be restrictions on number transfer from business to residential, if the business number is associated with a company.
It would really be best if I ask a moderator to comment on this, but they cannot help with BT Business, only residential. I will ask one of them.
Hi @Maisie-Moo
Thank you for posting the information at @Keith_Beddoe has posted is correct. If you no longer require your Business account you would need to place a working line takeover. With regard to keeping the number, your best bet would be to call BT Business on 08081000413 and they should be able to advise you on what needs to be done to transfer that number to a residential account.
PaddyB
Were you able to do this? When I called I was told this could not be guaranteed.
Were you able to transfer successfully from BT Business to BT Residential keeping your original number?
We are now retired and our business closed and our BT Business phone and broadband packages are out of Contract. I want to transfer both phone line and broadband to residential.
Hi @Scaro1 and welcome to the community.
The first step would be for you to contact the business guys on 0800 800 152. Ask to speak to a business retention advisor who will then be able to transfer you through to the correct team. There is a process in place where you can retain the number if requested. Let me know how you get on.
Cheers
David
