yodafarm
Newbie
Message 1 of 5
Trying to order ref# CON 0067
hi,
I've been trying to order Unlimited Infinity 1 for months now - via BT directly and also via TCB and Quidco depending on the deals on.....
it brings up all my details etc and lets me proceed until I get the the final checking phase where I get an error saying the order cannot be processed Ref# Con-0067
Any reason why I shouldn't be able to? Currently on Sky fibre and no problems - seems like switching to BT is a problem though 😞
Mark
4 REPLIES 4
Message 2 of 5
Re: Trying to order ref# CON 0067
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Perhaps the fibre cabinet is full, and no new orders can be taken?
In order to find out what services and speed range you should be getting, please enter your details (use address and postcode option)  into this form.
Broadband availability check
Please remember to edit out personal info before you post the results.
Moderator
Moderator
Message 3 of 5
Hi @yodafarm and welcome.
I'm sorry you're having problems getting the order placed. @Keith_Beddoe is more than likely correct in that there's possibley capacity issues so if you can post the information he's requested we can take a look for you.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
yodafarm
Newbie
Message 4 of 5
Thanks, all available though....as I say I'm already on fibre from the cabinet
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 80 69 20 20 -- Available -- --
VDSL Range B (Impacted) 76.4 45.6 20 14.6 -- Available -- --
Featured Products
WBC FTTP Availability Date
Left in Jumper
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
ADSL Max Up to 2.5 -- 1.5 to 5 Available -- --
Fixed Rate 1 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- --
Moderator
Moderator
Message 5 of 5
Thanks for confirminmg that @yodafarm.
I'm sure I can help with this. If I place the order for you it wouldn't qualify for any cashback offers as they're online only but if you want me to try and get this in place for you drop me over an email with your details and we'll take it from there. You'll get the contact the moderators link in my profile.
Cheers
David
Kudos”
