DoDa
Message 1 of 4
Unable to check balance on Reward Card
I had a BT reward card from New broadband contract, card came through OK and I registered it but was able to check my balance but now can't find that option anymore and it's due to expire Pires this month, I tried the Pure card option but doesn't recognise my card number on that site.
Rang helpline and tried live chat but both went to Asian call centre and were useless.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Unable to check balance on Reward Card
Hi @DoDa Sorry you are unable to check the balance on your Reward Card.
Please contact Purecard directly either by phone or email and they will be able to help you with this.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
DoDa
Message 3 of 4
Thank you, will do.
DoDa
Message 4 of 4
Thanks again , recorded message on answer phone gave me all the info for my reward card .
