NeilO
Moderator
Moderator
Message 11 of 11
Re: Unable to get final bill despite account closure
Hi @Guelfo83 no problem, I've checked over your account info and can assure you that no further direct debits will be collected so there's no need for the screenshot.
You can ignore MyBT, there are no chargeable services active and no further bills or direct debits will be collected.
Neil
