Message 71 of 75
Re: Unable to see broadband usage if on unlimited
The usage monitor only ever showed total usage there was no breakdown given
Dhiammara
Message 72 of 75
Apologies for dragging up this issue again but we will be moving home shortly, and being unlikely to get a fibre connection at the new property, we may need to look at satellite broaband where data is not unlimited. Since there is no usage monitor on an unlimited package how can I find out our usage so that we can obtain a suitable satellite package (if such a thing exists!). Is there a department at BT which can help?
Message 73 of 75
simple answer is no I am afraid
nokiauk
Message 74 of 75
I had this issue as well as I had to move and change to 4G broadband.  I just called BT and they were able to give me my usage figures for the last year month by month.
mattokun
Newbie
Message 75 of 75
Had the same problem myself as I needed to check usage for a WIFI router on holiday. Someone on the chat system helped me out straight away. Shame not available from your profile page.
