Moderator
Moderator
Message 11 of 13
Re: Unbelievable incompetence
That's fantastic news @Mickeyp4. Thanks for letting us know the enigneer was able to get this sorted for you. Are you happy for me to close this off at my side?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Mickeyp4
Message 12 of 13
and thanks once again
Moderator
Moderator
Message 13 of 13
Thanks for confirming that @Mickeyp4.
If you have any other problems please post back and we'll be happy to help.
All the best
David
Kudos”
