michaelkenward
Message 11 of 14
Re: Unfair engineer charges! Someone please help!
@john46 wrote:
Virgin now only provide cable broadband they sold off their ADSL services I think to talk talk
But TalkTalk also sold off its BT-attached ADSL to Fleur Telecom. I know, they dumped me. Which is why I am on BT. A lot better than TalkTalk.
Moderator
Moderator
Message 12 of 14
Re: Unfair engineer charges again! Someone please help!
Lets keep it on topic here guys.
@neilallen,
Are you having problems with your landline or broadband? If it the landline are you getting any noise on the line? Can you connect to the test socket behind the master faceplate and dial 17070 option 2?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
neilallen
Message 13 of 14
Hi
I have the same problem my Landline would receive calls but I could not make calls, It was fixed over the net but the problem came back, the bt guy came tested the line and all was fine.
I feel I would be better off with Virgin as they do not charge you when they are called out, my wife checked to see if she could make out going calls and got the same problem.
So If my line goes dead again I cannot afford to call the guy again.
I brought a new phone to braek down where the fault was.
So for me virgin looks the better bet.
Neil
Message 14 of 14
