chm2009
Message 1 of 6
Unknown number on bill
I have a number appearing 3 times on my recent usage, which ive no idea what it is, i cant find anything about it online apart from someone else saying they have had it on their bill but they havent dialled it. I phoned BT to query this and after a few minuntes on hold was told that they cant tell me what it is due to data protection ( ! ) The only way apparently I can determine what it is is to phone it ( and get charged ) again! Is there anyone that can help on here if I provide the number?
5 REPLIES 5
Message 2 of 6
Re: Unknown number on bill
did you try google and see if it a common problem
chm2009
Message 3 of 6
Yeah as I said im unable to find anything out about it online, which is very strange aswell as usually I can find numbers in there and see what they are.
Message 4 of 6
did you try using the forum search to see if anyone else had posted about the number  However if it had been posted on forum then I would have expected google to have found it
chm2009
Message 5 of 6
Ok ive found it now - it was a number we had phoned but yeah im amazed it wasnt on google!
Many thanks.
Message 6 of 6
Glad you solved your problem
