Moderator
Moderator
Message 11 of 15
Re: Updated BT ID - Now None of my Products are Showing
@Annimousey This is a quick update to let you know that we haven't forgotten about you. I'm sorry this is taking longer than we expected to resolve. We're waiting for updates from the bt.com programmers and as soon as we have any news we'll get back to you.
Moderator
Moderator
Message 12 of 15
@Annimousey Sorry about the delay getting back to you. The programmers have updated me to say they have had to delete your BT ID and have asked you to set it up again using the create BT ID in MyBT.  Can you give that a try and let me know if it works?
Annimousey
Message 13 of 15
@NeilO Just done and it's all working okay now. Thank you. 🙂
Moderator
Moderator
Message 14 of 15
Hi @Annimousey brilliant, I'm really sorry it took so long to get that sorted.
Annimousey
Message 15 of 15
@NeilO It's fine. I know how busy you all are. 🙂
