Message 1 of 6
Upgrade to Halo 3+
I've just been looking at my upgrade option, at present I have fibre 1 it says I can upgrade today for £2.50 less a month to halo 3+ but when I look at halo 3+ it's £44.99. How can I get Halo 3+ at my present monthly cost??
5 REPLIES 5
Message 2 of 6
Re: Upgrade to Halo 3+
Halo 3+ is a add on to your broadband package and is not an actual  broadband package
Message 3 of 6
Halo 3 and Halo 3+ are actual broadband packages, the promotion adds on all the relevant extras like the hybrid, double data, keep connected promise, it has no discount though because it has no out of contract increase.
Message 4 of 6
Thank you, they don't make that clear, it reads as a package
Message 5 of 6
@Chris201066 it may be hard to get Halo 3 or Halo 3 + for the same price as you are paying the now.
Looking at the cost of broadband and Halo 3+. It is a little dear a month even if you do get added extras.
Halo 3 is just the old halo 1. Halo 3+ is Halo 2 with maybe a few added extras.
There are other companies out there that offer similar to Halo 3+ and are a little cheaper a month.
Message 6 of 6
Not all are the same, only BT use the EE network for the keep connected promise, other ISP's use other networks - check coverage in advance.
Some have data caps on the 4G backup, BT have unlimited usage.
BT complete wi-fi has a £100 money back guarantee, others will refund only the difference for the disc/mesh upgrade
