DavebyC
Message 341 of 462
Re: Usage Monitor not updated
What, EdSurrey .....  BT using 'flakey' software?
Surely not .... My quarterly bill always arrives on time!
HHGTTG
Expert
Message 342 of 462
My BB usage meter is still stuck on 23rd May 23.59. Not good enough.
JAL
Message 343 of 462
Mine too is only showing up to 23 May. I find it hard to accept that a company that is so involved in using technology cannot sort what should be a simple issue.
NodNodWinkWink
Message 344 of 462
Re: Usage Monitor not updated since 23:59 01/01/2013
Usage Monitor also not updated since 23:59 on 23 May 2013.
Have been takeing Daily records for last 3 years  and have had similar issues before but this is longest time-our.
Surely the boys with the software toys share our woes and joys ??
Still, on the bright side - my Kaspesrsky Monitor suffices at present - - Good old BT  !!!
NodNodWinkWink
Message 345 of 462
WELCOME TO THE CLUB !
My Usage Monitor stats also not updated since 23:59 on 23 May 2013.Smiley Mad
Have been taking Daily records for last 3 years  and have had similar issues before but this is longest time-out.
HHGTTG
Expert
Message 346 of 462
I wonder whether BT have stopped monitoring charged phone calls over this holiday period, as well as not being able to tell us our BB usage?
I don't think so, somehow.
DavebyC
Message 347 of 462
I have emailed a complaint but don't have much hope ..... 1) Software bugs are the domain of BT India and 2) There's no 'R' in the month.  HHGTTG ... Perhaps the answer will be 42!
BT Help
This is an automatic response, please don't reply to this address
Thanks for your email. Your reference number is XXXXXX-XXXXXX. If you need to contact us again before we reply, please tell us your reference number.
Many technical problems can be immediately fixed using our desktop help tool. This FREE tool helps you sort out most common broadband connection and email problems, keeping you connected when you need it most. You can download and start using it now by accessing www.bt.com/help/broadbanddesktophelp.
Kind regards,
BT Customer Support
A1944
Expert
Message 348 of 462
Start checking it regularly folks.
It has updated to the reading for the 24th (but has not changed the date).
On past experience, it will probably jump up in daily steps from time to time over the next few hours.
iggyb
Message 349 of 462
My usage for the 23rd has now increaed, I assume the date will change later. The poor quality of this system is incredible
iggyb
Message 350 of 462
Date still 23/05/13 but usage risen again. It is unusual to update linked data (Date & usage) separately. This is really an odd system
