MrsMiggins1
Message 1 of 5
Viewing old bills
Hi all,
I need to see a list of phone calls I made in July 2018. How do I do this?
When I use the Billing History options on BT I can only see bills from the past 15 months.
(I use online billing; my bills are all itemised with a list of calls and have been since 2010.)
4 REPLIES 4
Matt-S
Moderator-Retired
Message 2 of 5
Re: Viewing old bills
Hi @MrsMiggins1,
Welcome to the Community and thanks for taking the time to post. You are only able to view the last 15 months within MyBT anything older than this you will need to call 0800 800 150 and ask for a copy of the July 18 bill.
Matt
MrsMiggins1
Message 3 of 5
Thank you. I will do that.
Carlusha
Recognised Expert
Message 4 of 5
@Matt-Swrote:
Hi @MrsMiggins1,
Welcome to the Community and thanks for taking the time to post. You are only able to view the last 14 days within MyBT anything older than this you will need to call 0800 800 150 and ask for a copy of the July 18 bill.
Matt
Hi Matt, I am sure you mean 15 months!
Matt-S
Moderator-Retired
Message 5 of 5
@Carlusha,
Yes, I sure did, I must be half-sleeping this morning. Thanks for pointing out my error I have updated my post 🙂
Sorry about that @MrsMiggins1
Matt
