ant_j
Message 1 of 11
Warning to leavers... 'Hidden' £31 charge
OK, so I'm moving to Virgin all services, phone fibre and line.
I received an email today specifying a fibre disconnect charge. I called bt on the number on the email, the employee was very rude... It's in your t&c mate
Now I state this was hidden as you would have to look hard in the T&C, with references another document to then see this.
Unfortunately this wasn't explicitly explained at the point of joining, but I am just offering awareness to others. If you move from BT to cable expect the charge. Needless to say I am not nest pleaded with this note the impolite team member.
Anyway... Hope this helps some of you out.
10 REPLIES 10
Message 2 of 11
Re: Warning to leavers... 'Hidden' £31 charge
The charge is raised by Openreach and passed on to all service providers not just BT the charge only applied to moves to cable operators all BT are doing is passing on the charge
ant_j
Message 3 of 11
Thanks John,
Who raised the charge and what it is for is of no concern, it's more the lack of awareness on my part and more so information from BT. Plus rude employees don't alleviate the situation.
As mentioned my post I hope will warn others. Thanks for the quick reply
Message 4 of 11
ant_j
Message 5 of 11
Goodness me.
Note the quotes around the word hidden on the title and detail in my post.
Is there a document available to describe what attitude I should have experience with the staff 😉
Guru
Message 6 of 11
There is NO excuse for rude staff.
Stew
Jane2018
Message 7 of 11
I was charged it or something similar when I closed BT broadband on one of my landlines and put BT broadband at the same time on to my other BT landline! I haven't had the strength to try to claim it back. I did not even charge provdiers and the cost was not mentioned on the phone.
Message 8 of 11
The cos is in the T's and C's.
It's an Openreach cease charge.
Message 9 of 11
@Jane2018
See http://www.bt.com/ceasecharge
somniac
Message 10 of 11
How about if the monthly charge increases? Aren't you allowed to stop the service without a charge then?
