essbee
Message 1 of 26
Wrong delivery address
I have noticed several others have had this problem which is kind of a comfort!
I've been trying for 7 years to get BT to log the correct address to send any equipment to. Our bills and correspondence come to the right address but physical equipment such as routers, accelerators, etc.  are addressed to the previous owner of our house and with no house name.
How on earth can I get Openreach/BT to log the correct address? The last router we had sent to us we only took delivery of because I intercepted the Parcelforce van driver who was on the verge of returning it with 'inadequate address' on the box.
We were going to upgrade to fibre but when the order tracking info. email came through it showed the wrong address AGAIN so we cancelled it!
Please can a moderator or someone help? Like another BT customer I was thinking of going public about this as it's incredibly frustrating.
25 REPLIES 25
roguesfi
Newbie
Message 2 of 26
Re: Wrong delivery address
BT Wholesale and Openreach use a database provided by Royal Mail, BT consumer ( The company that supply your service) need to contact them on your behalf to get this changed. Call 0800 169 1663 open a complaint and keep escalating to a higher manager (mention the ombudsman often) until they do this.
essbee
Message 3 of 26
I'm not doubting you but when I googled that number it seemed to the the BT Bereavement Service! I shall try it tomorrow.
Also, how is it we get our bills etc. with the correct address on?
Thanks for the reply.
Message 4 of 26
Is your address correct on Royal Mail database?  If so maybe mods could help get bt address changed
roguesfi
Newbie
Message 5 of 26
Essbee, bereavement is part of BT consumers Camp 2 helpteam (known internally as 2b) call tomorrow between 8-8  it's the best number available externally to help you. Good luck. 🙂
essbee
Message 6 of 26
Thanks, can only give it a try!
essbee
Message 7 of 26
Wrong address on equipment
I did post this in another thread but no Mod has contacted me and they seem to be the movers and shakers!
For 7 years since we moved to our house any equipment has had the wrong address on it. It shows the name of the man we bought it from, and with no house name. We only received a router because the postman recognised my husband's name but recently another piece of kit was about to be returned by Parcelforce as undeliverable.
I've tried numerous times to get BT to log the right address. Last week we decided to go for fibre broadband. The email confirming tracking info. showed, to my horror, the old wrong address! So we cancelled the order and are still using the copper connection.
Can a Mod PLEASE help me with this? I see they have helped others with this problem in the past. Something called an ORDI request needs to be raised and I understand I can't contact Openreach myself. Very grateful for any help.
Message 8 of 26
Re: Wrong address on equipment
you never replied to confirm your address is correct on royal mail database
did you also try the number that was posted?
essbee
Message 9 of 26
How can I know if it's correct on Royal Mail d/base? No idea where to start.
I thought I'd try to get a Mod to help me before calling that number as they have helped others but for some reason are ignoring me.
Message 10 of 26
I tried google  you could try google  i got this  https://www.royalmail.com/find-a-postcode
need to confirm address on royal mail is correct then can see if mods can help
you could give the number a call and see if they can help
