essbee
Message 11 of 26
Re: Wrong address on equipment
Yes Royal Mail address is spot on. As I mentioned, our BT bills and correspondence are showing the correct address. It's just Openreach where it all goes pear shaped!
essbee
Message 12 of 26
Trying for 7 years to get BT to use correct address-no luck yet. Should I contact Press/Ombudsman?
For 7 years since we moved to our house any equipment ordered has had the wrong address on it. It shows the name of the man we bought it from, and with no house name. We only received a router because the postman recognised my husband's name but recently another piece of kit was about to be returned by Parcelforce as undeliverable.
I've tried numerous times to get BT to log the right address. Last week we decided to go for fibre broadband. The email confirming tracking info. showed, to my horror, the old wrong address! So we cancelled the order and are still using the copper connection.
Can a Mod PLEASE help me with this? I see they have helped others with this problem in the past. Something called an ORDI request needs to be raised and I understand I can't contact Openreach myself. Very grateful for any help.
Message 13 of 26
Re: Trying for 7 years to get BT to use correct address-no luck yet. Should I contact Press/Ombudsma
have you checked the royal mail database yet?  onc eyou have checked that and confirm it has correct address then we can see if mods can help  don't know why you are so reluctant to provide information  i even posted a link which may help and someone else posted a number for you to call
Message 14 of 26
now you have confirmed royal mail is correct I have asked mods to try and help
keeping posts in one place is better
essbee
Message 15 of 26
Thanks Mr Jolly. And I thought I had started a new thread! Not terribly au fait with the way this BT Community works, not yet anyway. Grateful for the time you are giving me.
Moderator
Moderator
Message 16 of 26
Re: Wrong delivery address
Hi @essbee
Welcome to the Community and thanks for your posts!
Sorry for the mix up with your address.  I can appreciate how frustrating this is.  As this has been going on for so long you can send us over your details and we'll check your address details from here.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Message 17 of 26
@essbee
constantly starting new threads on the same subject just leads to total confusion hence best with posts altogether
essbee
Message 18 of 26
Yes I know, sorry, I didn't intend to. Just getting a bit desperate!
Moderator
Moderator
Message 19 of 26
@essbee thanks for sending in your details, I've raised a case to get your address details updated. This process can take approximately a week for the changes to be done and I'll get back in touch to let you know when it's been sorted.
Community ModeratorNeilO
Kudos”Kudos”
essbee
Message 20 of 26
Thanks Neil. I believe RobbieMac, another Moderator, is also working on my behalf so don't want you to get your wires crossed!
Also, I don't think I gave  you the right and wrong address details, did I?
