Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
I'm a new customer and my broadband was supposed to activate on Thursday the 11th. it didn't happen. so we called customer service and found out that's due to Open Reach serial number mismatch. they said they would send someone to fix it on Monday. no one turned up.
then we called again, they said not sure what happened and booked another appointment on Wednesday. no one turned up again!
again we called, again they were not sure what happened and booked another appointment on Friday.
this is just not acceptable! I'm working as an analyst so will need high speed broadband to work from home. now I apology to my manager every day saying I'm not able to work because I still don't have internet at home!
I assume this is a direct fibre (FTTP) connection?
If that is the case, then call the FTTP team on 0800 587 4787. And they should be able to help.
@ctxdlw wrote:
thanks for the info. I have called this number five times this afternoon but could not get through
That`s a pity, because if its only the serial number on the Openreach modem that does not match the records, then you may have been able to pass that information on to them yourself.
The problem is that Openreach are not visiting to do installs of FTTP, unless the end user has no other means of connecting to the Internet.
What do you mean you could not get through. Number just unobtainable or there was a queue ? Probably the latter and you really need to wait in the queue as @Keith_Beddoe posted they are the people who will probably be able to help you
the the FTTP TEAM on 08005874787 are the people to talk to for help
must be time of day as others have posted they got through very quickly compared to the standard CS number
