Moderator
Moderator
Message 11 of 12
Re: bt rewards card declined on 5 different websites?
Hi @mark74 Thanks for trying that. I will go back to the team that helped with the previous issue re the activation code to see if they can help. I'll update you as soon as they get back to me.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 12 of 12
Hi @mark74  sorry it has taken so long to get back to you. If Purecard have been in touch with you and sorted this post back and let me know. If they haven't I've sent you a Private message explaining how you can contact the forum moderation team. check here
https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Kudos”Kudos”
